Hi all,
I am looking for some sort of guidelines to help me choose on a tension control system for a continuous wire plating process. The wire would have to maintain a very small tension, as it constantly enters and exits many baths or cells.
Inside a cell, the wire is passed through sets of pulleys which enable it to stay inside for the required amount of time at a given running speed. The whole system would have an unwind and rewind for the wire. What concerns me is what to use in between the cells, to pull the wire and to control the tension. I have read about the use of magnetic clutches, capstan drive systems or just the motor itself to do the job. I am not well versed in these systems so I don't what is best for the job.
What would be the best system to use? What are the advantages/ disadvantages?
Thanks.
Thanks.
