F
I am a university student at Polytechnic inversity
and I am going to do a research for my B.Sc project about controlling a chemical reactor which is used for a Polyester resin synthesis.
There are some facts about our project and they are :
1)The dynamics of the process is known and we know a lot about the process mathematical model and the form of the equation, which is used to model the process, but we don't know the exact values of the model parameters (kinethic, reaction &rate contants and we could just estimate them prior to beginning of the experiment); We could just approximate these values by performing some experiments prior to the main experiments.
2)The process is to some extent sluggish (not so
sensitive). We are going to design a controoler that should follow a predetermined temperature profile at the range of 150 c to 250 c with a maximum of 5 c deviations from the set point.It is preferable to use a control strategy that help us to online monitoring of two process variables(except of the temperature) which guide us to reach high quality products (resins with known molecular weights and -OH saturation values which have special reaction temperature profiles).
Now I have some question from you who are control specialists and they are as follow :
1)What are the best control methods that we could
apply to our system to get the best results? why?
2)what are the things we should know about our system prior to performing the control strategies mentioned above?
If it is possible please answer me as soon as possible because we are seriously concerned to start our work at the university.
Thanks before hand.
Best Regards
Zand,F
1 Dec 2001
Thanks before hand.
Best Regards
Zand,F
1 Dec 2001
