F
The system is laid out as following:
One computer (PC1) with the communication card and the I/O server installed in
it.
Two HMI computers (PC 2 and 3) using Intouch 7.1 and accessing the I/O server
(Siemens H1CP1413) via suitelink.
The problem:
On PC2 a motor shows off (bit = 0)
On PC3 the same motor shows running (bit = 1)
This is not happening only for a few seconds, it remains like that until the
bit changes value. It is also happening on different motors. Analog readings
seems OK.
PC2 and 3 were replaced and the problem persist
it.
The problem:
seems OK.
