I want to use rs485 pci card istead of He693snp232a cable what is the best card i can use. thank you
S Thread Starter S.F. Moh'd Jan 15, 2002 #1 I want to use rs485 pci card istead of He693snp232a cable what is the best card i can use. thank you
A Anonymous Jan 17, 2002 #2 If you have a serial port on your PC with RS485 connectivity then you can directly connect with the port. The port on the 90-30 is RS485(9 pin).
J Jim Helgesen Jan 23, 2002 #3 B & B Electronics has good, reasonably priced PCI boards. They also have RS232/RS485 convertors that plug onto the existing serial port on a PC. Link: "http://www.bb-elec.com":http://www.bb-elec.com
