Barrier model support
R
Raja Mishra
Is there any Barrier model that can support two transmitters connected in parallel? I have an experience with MTL 706+ that if you connect two
transmitters in parallel, the output side voltage is dropping to 5VDC (input side voltage is 24VDC), whereas when I connect one transmitter, the voltage is 14VDC.
