L
We are looking for a linear potentiometer which is drived by a rotatory stepper motor.Though this potentiometer ,the ratational movement is
first change to linear movement and ultimately to an electrical signal.
The spcification and structure are as follows:
the length of the stroke:10mm,
resolution:<1/600mm
resistance value:12K or <12k,
made from conductive plastic element,
mechanical stroke:30turns,10mm,
startup torque:0.7mN.m
drive torque:<0.7mN.m
size:length<20mm,diameter<10mm or width<10mm.heith<8mm.
resolution:<1/600mm
