N
We are looking for off the shelf test equipment which can be incorporated into the assembly machine.
The test voltage can only be 200mV to prevent operation of any devices on the circuit board.
The test is required to check for continuity and shorts between other test pins.
We have looked at utilising 'cable test' devices but test voltages are genrally 5v.
Help appreciated in locating correct instruments or potential test methods.
