Looking for a Devicenet to RS485 Converter for 115Kbaud.
I've seen a lot of converters that do this, but I haven't found one that goes above 56Kbaud on the RS485 side.
I need to interface some RS-485 devices to a Devicenet network, and they can only do 115Kbaud. The device vender has a converter that will converts CANbus to RS-485 for their units, but I don't think that the CANBus will talk to the
Devicenet scanner that I'm using.
I've done some Devicenet in the past, but am relatively new to it. Typically work with Ethernet or ARCNET. I did look at the ODVA website, but unless you're a member you can't get to the technical stuff.
