Omron CX Programmer
Stuart Cameron
Has anyone had problems with the Omron CX-Programmer software and HP OmniBook XE3 notebooks under WIN2k. The problem I'm experiencing is that CX_Programmer cannot find my serial port - [COMM 1]. It does however find COMM 3, which I is my internal modem. All other software I use, including Omron sysWIN correctly finds COMM 1.
The problem appears to be related to the notebook as the software does work on my desktop, and on other notebooks.
Any help/thoughts would be greatly appreciated.
cheers
Stuart
Professional Electrics
123 Blenheim Road
PO Box 8563
Christchurch
New Zealand
Sebastien Ducharme
You could upgrade your windows 2000 with service pak 2 to correct the com problem.
I know that V2 is not officily compatible with 2000 but their is a newer version of Cx-Programmer. Version V2.1 is compatible with 2000. Usely , you can ask Omron representative for an upgrade.
Try it out!
Stuart Cameron
Unfortunately I'm already running windows2000 with SP2 and version 2.1 of CX-Programmer [version 1.6 of CX-Server]
Any other ideas
cheers
Stuart
Stuart Cameron
The problem I'm experiencing seems to be limited to CX-Programmer and HP Omnibooks. The serial port works ok on a variety of software including
Omron's sysWIN. CX-Programmer works on other notebooks we have, just not the three HP's we have just purchased.
Any thoughts would be greatly appreciated.
Any other ideas
cheers
Stuart
Ain't it a lovely problem. I am using a HP XE3 with an internal modem and a USB serial port. OS is XP Home. Think yourself lucky you have W2K. If you have an internal modem disable it. Re-boot.
Make sure you plug your serial converter into the USB before boot up. I also found it works better if I use the right hand USB port (when looking at the back of the laptop). CX-Programmer then should see the serial port. Took sveral hours to work that one out but now works fine.
BobB
