V
Hi list,
I am needing a small servomotor with low speed (4 rpm)and low torque, in my project it is necessary because the angle will be measured with high
precision, my tester will measure angle and output voltage of a potentiometer. Could somebody recommend to me a servomotor and its servodrive?
I need to control the motor in real time with a PC to adquire the angle value and potentiometer output voltage value (product under test).
Thanks...
Thanks...
