I was trying to establish communication between my PC (serial port) and Allen Bradley SLC 5/03 (channel 0- RS232 port). I did a autoconfiguration using RSLinx and selected RS-232 DF1 driver (Full duplex). No problem and I was able to see this PLC as node 1.
However, using RSLogix500, under Channel Configuration, I changed the driver from DF1 Full Duplex to DF1 Half Duplex Slave and dowloaded the new parameters.
Now, I have no communication with the PLC. When I do a autoconfiguration using RSLinx, an error message “Failed to find the baud and parity ! Check the cables and switch setting” pops every time.
The cable is OK. How can I establish the communication again ? Any suggestions ?
