Sunday, May 20, 2018
reading data from OMRON CV1000 PLC
i want to read and write data from/to OMRON CV1000 PLC.
dear all,
any help is appreciated.
thanx in advance.
jit
Is this another student project? I presume you are going to use the serial port. If you set it in host link mode, then the Omron host link commands are used for communication. Here is a link to the Omron manual with all the codding information you will require
http://oeiweb.omron.com/Home.shtm
Unfortunately the document library was unavailable when I tried to get the exact address for you. Just go to the above, select documant library, then select PLCs and then the manual for the CV1000.
By Anonymous on 30 June, 2003 - 2:42 pm
thank u bob i will try
