As u know SIEMENS CPU 928B has an SI1 and SI2 leds in front of card.when the cpu in stop mode only BASP led should be ON.In our application we are not use SI1,SI2 (Serial Interface 1,2).
Problem is this :
CPU is in STOP state and BASP, SI1, SI2 leds ON.But in normal conditions only the BASP led should be ON when the CPU 928B in STOP state.Because of the SI1,SI2 leds ON, i didnt reload my PLC program and also i didnt restart.
Is this problem result of electronic component malfunction problem or CPU928B data loss(Loaded from SIEMENS not user program) ?
Problem is this :
