Y
I am trying to implement a modbus protocol to communicate with a mitsubishi A3U PLC. After reading the manual, I have some difficulty to deduce the definition of the frame formation.
For standard Function (Eg. 01,02,03,etc)
- How to derive the "Device designation" code for a particular device such as X,Y,D,etc?
For Optional function code (Code 65-75)
- It is mentioned in the manual that the function 70 can be changed via some setting. If the function code is changable, how can I know what my current PLC is using for this function?
- What is the PC number in the message format?
- Is the Address refer to ID set on the AJ71UC24 in the message format?
I will try to implement the comm. code in Labview. Is there anyone who had build these type of code (Mitsubishi Modbus) before?
Thank you.
YikTH
Thank you.
YikTH
