In order to remotely talk via modem to a modicon 984-145 CPU, I feel it is necessary to change the memory settings for the communication parameters from RTU to ASCII.
The default parameters are RTU, 8, even, 1 and are used when the switch on the front of the CPU is in position DEF.
The 'supposedly' writable communication parameters are used when the switch position is in position MEM.
Who do I write my required ASCII settings to the memory on the CPU??
Any suggestions??
Any suggestions??
