G
I have a Siemens S5 928B with 64K RAM module (I think that is the biggest available). I have been adding a lot of analog signals and now it says there is not enough memory in PLC. Compression doesn’t help. Is there a way to see how much memory is being used for the different memory types? Is there a way to shift some of the reserved memory area from the DB to the P area? Am I going to need to add another processor? Hope some of you S5 guru’s out there can shed some light on this for me.
Glen
Glen
