In general, signal generators have a moderate to low output impedance. By definiton, a constant current source has a very high output impedance. One way to approximate a constant current source is to amplify the signal to a very high voltage and then use series resistance to set the current range. The other way is with active current control circuitry using op-amps.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
