I need to search a block of registers for the register with the least value (about 10 long). I want to set up a subroutine which TESTs the first two, takes the highest value and stores it in a pointer register to be used along with the next register for the next TEST operation.
I don't see a way to use indirect addressing, i.e. just use something like TEST #400120 as the value which is pointing to the next register. Is there a way? If not, maybe there some way to use IBKR/W.
