Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
We wish you a Hare Krishna
And a Sun Myung Moon!
-- Maxwell Smart
-- Maxwell Smart
www.control.com/rss/
I would like to have the difference between PCS7 and S7-400
Hello Arvind;
S7-400 is Siemens' top of the line CPU family of PLCs. They can be programmed in a variety of languages (IEC61131-3)and can be networked to other PLCs or Scada systems with ease. Great hardware, if a bit expensive.
Now, PCS7 uses S7-400 CPUs as part of its hardware base. PCS7 is a type of DCS (distributed control system) developped by siemens that combines S7-400 CPUs, industrial networks, batch and control software, specific programming platforms (CFC/SFC) and dedicated SCADA software to control large plants or industrial processes. It is able to interface directly with MES-level software (to exchange production data with management).
Here is a link to Siemens' presentation of PCS7:
https://pcs.khe.siemens.com/pcs7en
Hope this helps,
Daniel Chartier
Hope this helps,
Daniel Chartier
In which area PCS 7 will be used so that it will be cost effective over S7 PLC system?
I'll sugest you to not use PCS 7. The concept is good but the system is usable just for demo by salesmen. You'd better use S7 with WinCC, it'll be cheaper and easier to handle. In case you really have to use PCS7 you'd better buy a library for your type of application (typically chemistry). Do not use the basic libray, your customer won't be satisfied with that. I would say you'd better never use Siemens software for automation if you have the choice.
PCS 7 consists of both Step7 and WinCC as major software tools for the engineering. In addition to that there are some enhancements made to make engineering easier and more effective.
If I would have been asked I would prefer using PCS 7 over a S7/WinCC SCADA solution.
There is a difference of area to use both ways of engineering:
S7/WinCC is normally used in the factory automation.
PCS 7 is the product for process automation.
Manuel
Manuel
Related articles from Control
Engineering magazine- Liquid level sensor: Non-mechanical optical technology extends application possibilities
- Wireless manager for instrumentation and control devices
- Level sensor: Magnetostrictive device extends mounting options
- New podcast: One road to wireless instrumentation
- Tutorial: Instrumentation / DCS integration languages, part 1, EDDL
- FactoryTalk industry-specific applications launched
- Torque: Hall-effect sensor, reaction torque sensor, torque data acquisition
- Transient blocking circuit protection via acquisition
- Automation Fair event focuses on convergence, sustainability, and technical talent
- Rockwell Automation releases VantagePoint for plant data visualization
Subject to its Terms of Use.
