Tuesday, June 19, 2018
Problem Connecting Laptop PC to Controller via RS-232
Cannot get access to the OC950 via RS-232 while program running, and cannot find a way to stop program.
By Scott Hill on 9 June, 2005 - 12:57 am
I have three single axis controllers each using an OC950 card and each running a brushless servo motor. The hard copy of the BAS program I have sets the program to autostart on power up, then it implements an infinite loop which contains a couple subroutine calls to cause the servo to home and to cycle.
main
accelrate = 100000
decelrate = 200000
enable = 1
autostart = 1
intri5hi = 1 'estop routine
out7 = 1 'servo done
out8 = 1 'servo waiting at transition
while(1)
while(enabled = 0)
abortmotion
wend
if(inp2 = 0) then Call Cycle
if(inp1 = 0) then Call Home
wend
end main
As I understand it, I can't access the controller to upload the executing program via RS-232 while the program is running. The problem is that the program starts executing on power up so there's no point where I can initiate communications with the 950IDE software. How do I break the program execution so I can communicate with the card to make changes to the program.
I am using an RS-232C cable and 950IDE software on a laptop PC running Windows XP and when I try to upload the program from the card I get "target not responding". The status light reads [0.] which the manual tells me indicates the driver is not enabled, but the program is running. How do I get it out of the infinite loop to display a status [0 ]? I didn't set this up, but I need to get in and make some changes to the program.
Any help you can provide would be greatly appreciated.
Thanks,<br>
Scott Hill
Have you tried clicking stop all in the rad motion software?
By Jorge Rivera on 18 August, 2016 - 5:52 pm
This post have a long time, but now I have the same problem.
How do you solve that?
Thank you
