Saturday, May 26, 2018
0-5volt to 4-20ma converter
How can I converte a 0-5 volt signal into 4-20 ma?
I need to convert a signal from 0-5 volt to 4-20ma. How can I do this?
if you have siemens plc system u select input module 0-5 volt analog voltage i.put selection and get the calculated value in words to get exit from 4-20 mA analog out module.
other vise you need real convertor of V - mA.check in internet lot of different sourse are available to buy...
thank you sir...
i am sankaranarayanan..
Mumbai.
sankar_29kw@yahoo.com
If the device needs power then this will do the job converting a resitsnce to 4-20. It will power up a resistance device and produce a 4-20 out.
http://www.almegcontrols.com/4-20_converter.htm
and you have 4-20.
Thanks,
Bob Hogg
By EVANDRO VIZICATO on 24 October, 2005 - 11:05 pm
You can use a converter from Phoenix Contact. Visit the website http://www.phoenixcontact.com
Evandro Vizicato
evandro.vizicato@uol.com.br
By Ing. Molina on 24 October, 2005 - 11:35 pm
You are kidding right? i mean, use a resistance for god sake, how do you convert voltage to current? that's electronics basic.
good luck.
Well, a resistor will work when going from 4-20 ma to 1-5 volts. But it won't necessarily work going the other way. Current loop transmitters are designed to drive a load that can vary from application to application, from 50 ohms to 750 ohms, typically. A current transmitter is able to compensate for the addition or deletion of a loop instrument by using more or less power to drive the loop. A fixed-size resistor could not do this and voltage sources are not designed to power current loops. Voltage sources expect a high impedance measurement device to be attached.
A 250 ohm series resistor should do the trick.
By David Adams on 28 October, 2005 - 1:01 am
That will give them 0-20 ma not 4-20ma. Look at converters from someone like Weidmuller or Phoenix Contact.
Contact Pepperl+Fuchs..Model KFDx-DCV. Dip switch selectable voltage input and dip switch selectable output.
http://www.am.pepperl-fuchs.com/pdf/pa/documents/KFDX-DCV_Configuration.pdf
Phoenix Contact has a transceiver for this purpose, contact your local dealer.
By Lee Thanh Ha on 22 November, 2005 - 11:13 pm
Please send us your e-mail. I will forward an e-mail with circuit voltage to 4..20mA.
By xm131.4vn.in on 23 April, 2008 - 12:22 am
Let using IC: AD693, AD694 or using this simple cir:
http://www.delabs-circuits.com/png_circuits/arc20060212.html
Good luck! ^_^
hi.
u can use of adc and then dac for changing your span from 0-5 to 4-20 and use mcu.
If you can't make it in basic way like using resistors, you can provide signal conditioners on the market with several input signals as your (4-20mA) output signal. Like we've done on my previous project with several analog signals to convert.
We have been using these, try this:
http://www.m-system.com
You only can use a converter module, such as :ISO-U2-P1-O1. That price is very good, easy to use.
About the datasheet, check the link:
http://www.szsunyuan.com/sy/product_list_2.asp?pageno=2&Cid=129
