Suppose I have to install Orifice plate in a line for which I know the Line Size, Flow range, Pressure Range, Operating pressure & temperature range. As well as Viscosity. How can I calculate the Orifice detail? How can I calculate dp, beta ratio? Do you know some software where u feed the detail you know and it will calculate the beta ratio & dp? and orifice thickness? I mean free software. Please help me. I need it urgently.
Hello Sunil,
You might find your answer at http://www.engineeringtoolbox.com/
Start by looking at the Bernouilli equation. You must take into account whether your fluid is compressible or not!
Gabriel
It is better to go through BS-1042. In case if you encouner any problem, please do not hesitate to contact me.
Arun Kumar
E-mail kumar.arun@power.alstom.com
Daniel flow has a downloadable flow orifice calculator that is menu driven and very to use. Daniel is a division of emerson electric.
A couple of sources for rigorous calculation procedures are:
R.W. Miller / Flow Measurement Engineering Handbook / McGraw-Hill
ASME standard MFC-3M-1985 or the latest version
There are many other less precise procedures also available
John Catch
http://www.inflowinc.com
muthuraman,
A more precise assembly of calculations can be found in " L. K. Spink's "Principals and practice of flow meter engineering".
These are user friendly and directed at the plant floor.
Dennis
