I have a SLC 5/04 in a 10 slot rack that I set it up for training purposes. The problem I have is communicating with the SLC 5/04 via RS232 port with the 1747 CP3 cable hooked up to a serial port on a laptop. I can communicate with the PCMK card but not with the 1747 CP3 cable. I would like to know if anyone had this problem before and how did you fix it. The card itself it costs at least $600 on EBay, plus the cable. This 1747-CP3 cable cost $25 or so, but I can't get it to work. There is another one that uses a USB port on a PC, but I am not sure if it works. I am using RS LINX and RS LOGIX 500. I have installed the driver for the RS232-DF1, but I cannot see the SLC 5/04. Please help!!!
