Thursday, February 22, 2018
Flow measurement in an open channel
Need to measure flow of waste water
Could any body suggest or have experience how to measure flow in an open channel. Fluid is waste water, biological water and chemical water in a pharmaceutical plant. I was thinking about using ultrasonic level transmitter.
Also I need flow totalizer (one with auto reset and other with reset in same device).
If anybody has experience of using any product for the same or similar application please share experience.
Imran
By Issac Issachar on 23 February, 2007 - 12:17 am
Buy a commercial channel flume like one of these:
http://www.tracomfrp.com/parshall.htm
Put an open channel ultrasonic flow meter like this:
https://pia.khe.siemens.com/index.asp?Nr=10848
Issac Issachar
By Michael Batchelor on 25 February, 2007 - 10:15 am
I have used exactly this type of arrangement on a number of jobs, and it works fine. Meets all the local municipal discharge monitoring regulations, etc.
If the plant has particular "favorite" suppliers, they're probably going to work fine. The flume technology has been around and understood for decades - if not centuries, and how you measure the level in it can be most anything you like. The ultrasonics work great, and seem to be the industry favorite, but I have seen bubblers on occasion.
The most unusual one I have ever seen was an ancient thing made by BIF that used a float which moved an arm on cam that controlled the on/off duty cycle of a telephone circuit back to the control room. In the control room was a
receiver that accumulated the total and derived the flow. We replaced the receiver with an input to a Modicon doing the conversion in the PLC, but the 50 year old float and cam was left in place at the flume.
MB
Michael R. Batchelor
www.ind-info.com
GUERRILLA MAINTENANCE [TM] PLC Training
5 Day Hands on PLC Boot Camp for Allen Bradley
PLC-5, SLC-500, and ControlLogix
www.ind-info.com/schedule.html
training@ind-info.com
Industrial Informatics, Inc.
1013 Bankton Cir., Suite C
Hanahan, SC 29406
843-329-0342 x111 Voice
843-412-2692 Cell
843-329-0343 FAX
Imran,
Look at Miltronics model OCM devices.
Dennis
By Rahul P Sharma on 24 February, 2007 - 2:30 pm
Use Ultra Sonic Level (and hence flow) transmitter-cum-monitor-cum-integrator by Nivelco (http://www.nivelco.com) for an open channel application... all you may have to do is to make a Parshall Flume of one of the standard types that the instrument supports... There is even a general parshall flume structure which the unit can be programmed for... Just feed in the basic raw data of the parshall flume and you should get a fairly good reading of flow... For exact model number etc you can write back...
au revoir
Rahul
This is typically done with a specifically shaped narrowing of the channel called a Parshall Flume. Yes, an ultrasonic level transmitter is typically used as the feedback device and the level in the flume is proportional to the flow rate. Companies such as Siemens/Milltronics have ultrasonic devices with built-in algorithms for such applications.
Hope this helps.
Imran, Grab any basic civil engineering book and look up flow wiers. They show how to calculate the flow (of standard water, you may have to calibrate for anything else which is true for any measurement device) based on the shape of the V (or flat bottomed V obstruction placed in the flow. It's kind of like an orfice plate used for closed pipe measurements where you measure the flow based on pressure difference across the orfice. With the weir,the "pressure difference" is the height of the fluid flow as it passes over the weir. Ultrasonic seems to be the way to go, or even possibly a simple arm float with analog output. I'm not familiar with the Parshall Flume. I'm sure someone would be glad to sell you one for bucho bucks but you can simply construct your own based on the shapes shown in the civil engineerng books. You have to calibrate anyway since you have fluid other than clear water, so why spend the big bucks. very simple.
good luck
John
There are many suppliers of this type of device
Siemens, Pulsar, Ohmart-Vega, Ametek Drexelbrook, Fisher Scientific/ThermoElectron, Endress Hauser, to name a few.
L Kolbert
Hope this helps.
By M A Muqtadir on 3 March, 2007 - 2:46 pm
The ultrasonic level sensor is mounted above the flow stream and transmits a sound pulse that is reflected from the liquid surface. The elapsed time between sending a pulse and receiving an echo determines the level in the channel. Because the sensor does not contact the liquid, the 3010 provides long-term dependability with no scheduled maintenance. It is ideal for measuring flows containing harsh chemicals, grease, suspended solids or silt.
Try with Teledyne Isco Products.
Hope this will help you.
Best of Luck & Regards,
M A Muqtadir
Saudi Arabia
