member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Bore, n.:
A person who talks when you wish him to listen.
-- Ambrose Bierce, "The Devil's Dictionary"
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the Control Panel department...
Can I do this?
Application Questions and Problems topic
Posted by Jairam on 30 May, 2008 - 12:22 am
Many of our control panels are in the field area where summer temperatures outside reaches 45 Deg C. Some panels also have sensitive electronic cards like Driver card for a Servo Hydraulic Control Valve. The panel has other electrical and power supply components too. Power supplies' heat sinks are also at high temperature.
I propose to cool the panel by allowing 7 Kg/cm2 of dry (dew point value around -55 Deg C) Instrumentation air to bleed through a very small orifice inside the panel. Will this scheme work? If yes, what can be possible risks in doing it?
Posted by C Potdar on 1 June, 2008 - 3:50 pm
Dear Jairam,
EXAIR, US provides solutions for cabinet cooling. They provide "Vortex Tube type Cabinet Cooler" which are well designed keeping into consideration heat load of the cabinet and also come with temperature control for energy saving. You may visit http://www.exair.com
C. Potdar
Internet Explorer 6.0 Fix
Advertisement
