Analog Signal
T
Test
Why people are using mostly 4 - 20ma instead of 0 - 20 ma?
Mail ID: aakarthikeyan @ rediffmail. com
Curt Wuollet
It gives you a live zero so you can tell the
difference between zero (4ma) and an open
wire (0ma). Also it provides 4ma to run
loop powered transmitters.
cww
R
Robert Scott
The 4 ma. minimum current flow provides power for loop-powered sensors. If you allowed the current to go to 0, then loop-powered sensors would not be able to operate. Also, having a current that is supposed to be from 4 to 20 ma. means that a cut cable can be detected as a fault.
Robert Scott
Real-Time Specialties
