PLESY P Software for HIMA PLC
  • Thread starter Mihir Ramkrishna
  • Start date
Mihir Ramkrishna
We have HIMA H-51 PLC with a DOS based PC used as a MMI. We have the PLESY P software running in this MMI. This software is responsible for alarm logging & recording sequence of events with millisecond timing.We are in the process of synchronising the time of this recorder with the DCS. We would be using a Global clock for the same. What time does the Plesy P software take? Is it the PC time of the PLC processor time? We can implement the global clock after confirmation on this query.
Hi
Plesy-p standardly use PC time and set time in CPU. Plesy can read time from some drivers,
for example PC31 etc,.
N
The master time can be taken from the PC or the PLC. This is configured within PLESY-P. Optionally a realtime clock building block could be added to the PES to enable the DCS to synch the time by either setting it to a predetermined time once each day e.g. 12:00am, or by writing to time and date registers then sending a synch bit over MODBUS if available.
