member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
You should never wear your best trousers when you go out to fight for
freedom and liberty.
-- Henrik Ibsen
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the Repair department...
B&R HMI PC
Human-Machine Interface and SCADA. topic
Posted by Jim on 20 June, 2008 - 12:56 pm
I have a faulty B&R pc type 5C2000.03 which won't boot although powers up with HD whirring. There is no output from its 15 pin vga monitor socket so BIOS not kicking in. After power up I get long beep followed by three short beeps and HD continues to do something. When it was connected to its HMI screen it wouldn't boot either.
Has anyone out knowledge of these small pc's.
Email replies to jim.shack079@ntlworld.com.
Posted by Michael Griffin on 21 June, 2008 - 4:01 pm
I would suspect the problem is either a bad motherboard, or a bad power supply. Check the power supply output voltages (or plug a spare power supply in). If the power supply is OK, then it's probably the motherboard.
Before you do any testing though, try unplugging all the possible peripherals (hard drive, CD-ROM, printers, network connections, etc.) to try to isolate the fault. It won't boot without the hard drive of course, but according to your description, you aren't getting far enough for that to matter.
Posted by Curt Wuollet on 21 June, 2008 - 4:13 pm
Good luck, we have several machines that
use various B&R pcs. Information seems to
be very hard to come by. I've been replacing
the old ones with generics. They are also
unbelievably expensive.
cww
Posted by Andy on 1 July, 2008 - 1:36 am
How much is a secondhand one worth to you working?
Posted by Curt Wuollet on 3 July, 2008 - 12:39 am
Not much. If you can do it well, the generic solution is a far better deal in every aspect. The proprietary PC may have some advantage for the machine vendor. but from the user's perspective it's a ripoff from day one and gets worse as it gets older. I had one vendor that wanted $20,000 for a replacement console. No Joke. The press now sports a $500.00 IBM Think Centre and some special keystrips at a savings of at least $15,000 being generous for my time.
cww
Posted by Jim on 27 August, 2008 - 9:57 pm
Suggest a price and we will consider it if reasonable.
Internet Explorer 6.0 Fix
Advertisement
