Hello, similar thread about 5 and 7 element drum control made me thinking about how to develop boiler drum model that will represent drum dynamics around some operational point.
For example, if you need to perform system identification, first you need to choose input and output variables. I have seen various drum models, but I wonder if it is possible to model only drum level. For example, to try to amke model with the following input variables:
Feedwater flow, Steam flow out of boiler, Pressure of feedwater and output varible is water level in a drum.
Since 3 element control that is often used measure three variable: drum level, feedwater flow, and output steam flow, I think it is sufficient enough to use these variables + feedwater pressure to obtain fairly accurate model that will good describe dynamics arounf operational point.
What do you think? Will this be enough?
