member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Radioactive cats have 18 half-lives.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
CSP-Control Sequence Program
Posted by AVC on 3 July, 2008 - 11:07 pm
Hi everybody. I'm a "potential beginner" in process control. I've been reading some stuff about control and I couldn't manage to figure out what the Control Sequence Program carries out. Is it the program, i.e., the sequence of actions a controller executes in a DCS? Or, perhaps, is the CSP above a controller in any way? "Who" is executing the CSP in a DSP? Is it a term related to each controller?
Thanks in advance.
Posted by CSA on 5 July, 2008 - 11:09 am
If you've been reading about the Control Sequence Program (CSP) in GE-design heavy duty gas turbine-related threads discussing Mark V turbine control systems, CSP refers to the software program which is downloaded to the turbine control processors (which have Intel 80186 microprocessors) that monitors, controls, and protects the turbine (combustion- or steam turbine) and its auxiliaries. It is a relay ladder diagram-type software program, "written" or edited using a proprietary program called the Control Sequence Editor. Once the program has been created or modified, it must be compiled, and then downloaded to the processors in the Mark V turbine control panel. The processors are then re-booted and the CSP is loaded into the RAM of the processor and then executed, usually at a rate of approximately 8 Hz (0.125 seconds).
You should know, if you don't already, that instrument and control technicians and engineers are an aging lot and there is a huge need for trained, qualified technicians and engineers in industrial- and power plants all around the world. This is a good profession, and you can make a good living and enjoy a lot of success and meet and work with some really good people. You can be hands-on, or hands-off; technical or practical.
It's an exciting time in the instrument and control profession, there a lot of new innovations coming down the "pipeline". Devices are getting a lot smarter, and there is some interesting software being developed and tested that actually runs models of the plant or equipment and compares the performance of the plant or equipment against the "ideal" model and provides information to the operators and maintenance personnel to improve plant performance or anticipate potential catastrophic problems.
Additionally, data retrieval and archival systems are improving all the time and are proving to be pivotal to ongoing operations as well as performance improvement and problem analysis.
All of this is going to require very well-trained and knowldegeable people to configure, maintain and troubleshoot.
So, if you're a person who likes to learn something new almost every day (sometimes it's a good lesson; sometimes it's a bad lesson!) and work with new equipment as well as older equipment, and can handle a little bit of pressure from time to time, this is a great profession.
Good luck!
Posted by Radhakrishnan on 5 July, 2008 - 11:10 am
These jargons are vendor-specific. In Speedtronic Mark V control system, Control Sequence Program (CSP) refers to the complete logic that is executed in the controllers <Q> (<R>, <S> and <T>) and <C>. CSP, in this context, controls the startup, control shutdown and protection of a gas turbine and the load (generator, pump or compressor)
The logic is created off-line on a PC and downloaded to the controllers.
The term CSP referred to by a general-purpose PLC or DCS could have a similar context.
Internet Explorer 6.0 Fix
Advertisement
