Exporting a POU from MicroWin for S7-200
Z
zimbricd
I am trying to export a POU but "Export" function is grayed out. I have tried to right-click on my MAIN (%OB1) block and select Export, but it is grayed out and I cannot figure out what i am doing wrong. I am trying to do this in IEC-1131 mode. Thanks!
Marc Sinclair
IMPORT and EXPORT only work in SIMATIC Mode, Why do you want to use it?
Marc Sinclair
Dave Zimbrich
I was hoping to port the logic over to another IEC program editor and reuse the code. It would be a lot easier than retyping the code from scratch.
You can export the logic over as a text file in stl code and then maybe you can import that into your other application.
Marc Sinclair
IEC is a standard, but it's not that standard. :(
The export only exports in a proprietary format anyway.
Marc
Marc Sinclair
No, you can't, STL is not available as an IEC option in the current version of MicroWin.
Marc Sinclair
