- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
www.control.com/rss
cww
Well there is an analogue signal for tank level on both tanks. I could control digital outputs from PLC to the inverter using these. Any suggestion of a specific suitable inverter, to control 1.5 KW 3 Phase AC Motor. speed.
cww
Did you read which PLC is best. Basically the same thing. Stock on hand in your counrty, hands on 24hr technicians, local experienced trades people, customer support and training options, ease of use (room for the neutral screened cables and good clamping systems) and last of all cost an extra $200 dollars now over a normal minimum operating life of 20,000 plus hours is nothing.
All modern drives have analogue inputs so if a PLC output is out of the question make that on/off/run return from PLC and transducer direct to the drive, or signal convert an existing transducer to do both jobs.
Best of luck Jason.
don
wdonpjr at gmail. com
- PLC origins: Where did PLCs come from? 40th anniversary timeline
- Acoustic measurements: Tutorial on decibels, microphones
- Vision help: Service helps users implement imaging algorithms
- Data integration: See, use, study integrated automation information
- OPC: Easier software; IEC 61131-3 programming for unified architecture, training
- New EZ Jump terminal blocks from ASI
- Hammond Control Power Transformers, more industrial options
- HART communicator: Low cost DD-based hand held
- Pressure sensor: New design compensates for challenging environments
- Listen in: Device conditions, consolidates multiple temperature sensor signals
