Siemens PLC connection question !
JamesTsai
If machine in different country. I wanna use internet connect to PLC. Can I how to setup on step7.
Sorry you mistook my meaning entirely. That's my fault.
I use PLC type: S7-300 315(7)-2 PN/DP
Thanks a lot for reply!
Hello;
The 317-2PN/DP supports Profinet-IO and TCP/IP connection, so maybe something could be done towards your application using the integrated Ethernet interface.
However the setup required goes beyond simply connecting to your ISP's line.
Here is a link to a series of FAQs discussing WAN setup and remote Internet connections for Siemens equipment.
http://support.automation.siemens.com/WW/view/en/26662448
Hope this points you in the right direction.
Daniel Chartier
Marc Sinclair
How is the PROFINET configured on the system?
Is it connected to the outside world?
Marc Sinclair
