GE-9030 C Block forTurbine Control
Posted by Generallist on 10 July, 2008 - 12:05 am
I have a customer wanting to upgrade from a GE 90-30 PLC to a GE RX3I. The PLC is used on a Gas Turbine Generator. One problem I have is that there is a C Block in the code that I have no idea what it is doing. I do not have the source code for the C Block and cannot find any references on how to dig into it. I was wondering if any of you knew what may be contained in the block that is such a secret.
Posted by Drake Fink on 27 September, 2008 - 9:38 pm
C-blocks are used for many reasons: complex calculations, hide proprietary algroithms, improve speed of doing control. If the 90-30s are running MaxON software, then the C block contains configuration data that's updated by the MaxON configuration program. Suggest you contact the manufacturer of the control system to determine what the C-block does.
Drake Fink
Applications Engineer
GE Fanuc Intelligent Platforms, Inc.
drake.fink@gefanuc.com
Happiness isn't something you experience; it's something you remember.
-- Oscar Levant
Advertise here
Advertisement
our advertisers
