O
I am currently working on an PLC upgrade from Micro to Momentum. I want to get the Quantum PLC to talk to the Momentum PLC using the Modbus protocol. I found XXMIT block in Concept 2.2. Quantum PLC will be the master & Momentum PLC will be the slave. I had the xxmit block implemented in the Quantum PLC. My question is, do I have to set up the the same block in the Momentum as well because this block activates the Modbus port coms?
Could anyone help me with this? Thanks.
