Intergraph Intools Problem
Apple
I'm actually quite new user of INtools. Now I have a problem with this program. I have changed the data by used spec binder module. when I updated the revision the highlight changed was not show but it's show on the summary report. Do you any idea what might be the problem? I have tried to fix it by deleting that new revision and then changed data on data sheet again then tried the print preview and there is no shown change mark again.
If you know how to solve this problem please advise me.
thank you
Carlo Snoeij
Dear INtools user,
When using the spec binder, select "Formal issue" when printing to file.
Hope this helps.
Carlo Snoeij
CS CADservice
