Hi guys,
I have a 6RA70 DC Master drive.
I have a single normally open contact available from a PLC.
With the contact normally open, I want the drive to run in the so-called forward direction.
If this contact is normally closed, it means the drive then reverse the motor in the opposite direction from the main setpoint. This is an extruder application where such a thing/application is used to remove material being extruded which has accidentally hardened during a drive/system fault and perhaps we need both directions of operation to free the material. I have a jog forward and reverse. I need sometimes to give a bit more umph...
Can someone help me on what parameters I need to program in the drivemonitor program?
