Hi there,
Apologies if my questions are quite basic as
I'm quite new to the topic.
First, I'm unfamiliar with the term hunting.
I'm currently modelling a CHP unit with a gas turbine prime mover. The modelling is based on that provided by W.I Rowen that consists of three control loops (speed, temperature (and IGV)and acceleration. The aim of the simulation is to investigate the dynamic behaviour of the gas turbine when subjected to different modes of operation.
The one i'm currently simulating is two machines operating in parallel interconnected to the grid, with one machine on droop control (loaded to 0.7pu) and the other on isochronous control (loaded to 0.9pu). A load of 0.45pu is then added causing an overload. I've been asked to investigate the hunting between the two. I've had a look through many text books and articles, but have not been able to find one that describes the phenomena well. I've done a test simulation, and found that although the machine on droop control reacts as expected and picks up the required load, the machine on isochronous mode fails to pick up any.
Should this happen? I hope you'll be able to answer my questions. Thanks
