Z
We are trying to connect a PC with PLC 140 CPU65150 with Unity Pro XL by USB Port. When with try to make a connection with software the system gives the following message:
Failed To Connect to the currently select target, this is not a valid PLC address, or PLC is busy, or media is OFF
But when we check the communication parameters driver setting, the icon shows the following:
Virtual Port: COM2
Status: Connect
Remote IP:90.0.0.1
Local IP:90.0.0.2
Please help us with this.
Thanks in advance.
Virtual Port: COM2
Status: Connect
Remote IP:90.0.0.1
Local IP:90.0.0.2
Thanks in advance.
