We had carried out combustion inspection of our gas turbine GE Frame 9 running on Mark-V control. When the unit was started after end of combustion inspection, the load was less than before by about 2-3MW and turbine compartment temperature after running for a few days started increasing and alarm appeared for Hi-Hi temperature. We had both turbine compartment vent fans 88BT-1 and 2 in service already due to this problem which started 2-3 years ago, but was not so bad.
Leak search was carried out and found leakage at combustion wrapper joint and near cans #4 and 11 at each end of horizontal joint of the wrapper. The unit was shut down and bolts re-tightened. The unit was re-started, but still temperature of the compartment is running high and load is also low. All other parameters have been checked and found to be ok. Just 2 purge air valves VA33-1 and VA33-2 for water injection were found closed due to wiring problem, which were opened, but there is no effect on load or turbine compartment temperature. Water injection system is for NOX control when running on HSD oil, but we have never used it. The unit runs at 100% fuel gas. I am wondering could there be any effect inside the hot gas path parts of the turbine due to closure of these two purge air valves?
Thanks.
Thanks.
