We have a so-called electrician that considers motor frame grounds to be an unnecessary evil he can't be bothered with. His negligence even applies to 480 volt fan motors on wooden cooling towers. These "unneccessary" frame grounds are in fact the only grounds to be found on the fan tower motors because the conduit is coated in PVC and is merely strapped to the grounded aluminum cable tray.
The NEC clearly states the need for industrial motor frame grounding in addition to conduit grounds but this guy claims that power plants don't fall under NEC jurisdiction. So I'd like to know what code covers power plants so I can maybe convince this guy and/or his boss that he needs to get with the program.
