member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
By doing just a little every day, you can gradually let the task
completely overwhelm you.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the Forum department...
Twido VF counting
Engineering and workplace issues. topic
Posted by scda on 3 June, 2009 - 6:22 am
I have to measure a metal sheet and to cut it to a specific dimension. For this small application I use the following: - ---Twido PLC TWDLCAA10DRF-XBTN200
To measure the metal sheet length I use a robber wheel mounted on an Heidenhain TTL 1000ppr encoder.
Can I connect the TTL encoder to the very fast counter inputs on Twido PLC?
If not what type of encoder I should use?
Thank you in advanced for your short answers,
Cristian
Posted by hummaid on 31 October, 2009 - 9:41 am
First you need to know what the maximum frequency is you are going to measure with that encoder!
Second you need a PLC with a fast counter input which is capable of detecting and counting the pulses of you encoder!
End third, you need to write a user program to handle what you wants to do!
What concerns the Twido PLC. Some type have fast counter inputs, up to 20kHz!
following website will show the wiring
http://www.infoplc.net/Ejemplos/Ejem_Schneider/Ejem_Schneider_ ENCODER/Ejem_Schneider_Encoder.htm
Advertisement
