We have S5 and CEMAT V4.12 over Ethernet SINEC H1. Communication port S5 is Profibus and Ethernet. Does anyone know
1 - When using H1 type of connection, what configuration to be done in INAT OPC Server and how can i determine the LOCAL and Remote TSAP?
2 - When using TCP/IP as type of connection what ports to be used for reading and writing, and how can i determine whether to use PLC Header or No Header or to use RFC 1006?
3 - What type of connection is preferable, can i have the option to chose between H1 or TCP/IP type of connection to be used with S5 protocol.
