In the nickel refinery fluid bed reactor I'm working on, there's a volumetric flow meter VERIS Verabar V510 (element) with a SMAR LD301 remote mounted transmitter.
The process gas being measured is compressed air. I understand why the temperature compensation as density of air changes with temperature and hence so does volumetric flow.
But why is there pressure compensation incorporated into this flow measurement?
