member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
"I can't decide whether to commit suicide or go bowling."
-- Florence Henderson
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the Forum department...
OPC with Honeywell TPS APP NODE & Simatic S7
Open interfaces, software and hardware topic
Posted by krk on 18 September, 2009 - 1:41 pm
Anyone has the experience of using matrikon opc data manger to communicate with honeywell APP node (HCI.TPNserver) and Siemens S7 OPC server (OPC.SimaticNet). Trying to establish bidirectional communication with them.
Please reply.
Posted by Adriel Michaud on 23 September, 2009 - 3:34 pm
If you need a hand, your best bet will be to contact MatrikonOPC's support at www.OPCSupport.com
Adriel Michaud
MatrikonOPC
Posted by Bill Graham on 24 September, 2009 - 3:52 am
Have you got a data historian system that can read the data in to first using a true OPC Client ? It is often less problematic than trying to connect 2 OPC Servers directly. This kind of setup is notoriously bad at recognizing interruptions in the Comms and you can often end up with flat lined data.
I have found both Matrikons OPC Data Manager and Emersons OPC Mirror to suffer in the same way. It can cause you a world of problems in the long run. Neither one, in my experience, is great at recovering after an outage either.
Best of luck.
Bill Graham
Industrial Thinking Ltd
Advertisement
