I am working on a project related to online auto tuning of a BLDC motor (speed control). The rating of the motor is 24V, 100W, 1500rpm. For this,I need to formulate a control loop to limit the current to safe values. The speed loop comes outside the current loop.
To measure the current in the three phases, I have put a 0.1 ohm 10W resistor in series with the phases. The voltage drop across the resistors is measured with an AD-620 instrumentation amplifier from Analog Devices. The problem is that the output voltage is showing me only positive values, even though current flows in either direction through a phase. The Ad620 IC has been given a supply voltage of +-10V. If I reverse the input, then it is giving me only negative values. This same problem is there in the other three phases as well.
I would be grateful if anyone comes forward with a solution.
Thanks and regards,
Control_expert
Thanks and regards,
Control_expert
