Jump to a Date
Twitter Feed
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Real programmers don't bring brown-bag lunches. If the vending machine
doesn't sell it, they don't eat it. Vending machines don't sell
quiche.
quiche.
www.control.com/rss/
OK, now assume I am a new learner. What exactly do you mean by Cv of a pressure regulator / pressure reducing valve? How it helps in valve sizing and after working out the Cv with all the factors required, how is the seat size defined in a pressure regulator? I am so confused.
Hello
The Cv is the flow coefficient of the pressure regulator or the control valve and it is measured in GPM (Gallons per minutes) for us units , which means How much flow is going through Your regulator or valve. the bigger the Cv the bigger the valve/regulator.
regards
Yaser
regards
Yaser
Most of the regulators I buy are rated in Volume units, gallons per Minute, CFM or the metric equivalent. However there's no reason they couldn't rate them in Cv (higer CV higher Volume). The seat size is just the size of the hole (orifice). Larger orifice = larger Cv = more flow.
Talk to your regulator vendor about this, you will get a more detailed answer.
Roy
Roy
