member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Paranoia is simply an optimistic outlook on life.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the Forum department...
Forced Coils in Quantum using Proworx
Posted by mavh on 6 November, 2009 - 10:59 am
2 Days ago I was adding a timer on a Modicon Quantum 113/03 using Proworx. I forced the contacts on the shutdown logic of a compressor, to edit on the coil of the same contact. It was a LSHH. The problem was that, even though the contact on the shutdown logic was forced, when I erased the coil, the force in the contact was removed automatically. That executed a shutdown sequence on the 2 compressor that work on cascade.
Later I did the same thing with many contacts/coils to reproduce the event, and it worked the same.
Is it normal? Has this thing happened to any of you? Is it something I'm missing?
I will appreciate your help on this, because, to the best of my knowledge, this shouldn't have happened.
Thanks in advance.
Advertisement
