member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
I have discovered the art of deceiving diplomats. I tell them the truth
and they never believe me.
-- Camillo Di Cavour
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the electrical and instrumentation department...
Selecting a control valve
Posted by rajiv on 6 November, 2009 - 11:04 pm
How to select a control valve? process fluid is hydrocarbon. then which valve to be select, globe, butterfly or ball. flow rate is 800GPM (US). decided by process.
what flow characteristic i should choose.....linear or equal%?
i know that first we have to calculate CV then we have to match with vendor specification.
want a elaborate knowledge ...if any kind person helps me ..i will be grateful to him
Thanking You
rajiv
rajiiv_kumar2000 [at] yahoo.com
Posted by Roy Matson on 7 November, 2009 - 2:27 pm
We need more information.
What are you trying to control, flow, level, pressure?
What is the upstream/downstream pressure?
The valve will likely be a ball, butterflys are used for low pressure drop.
Roy
Posted by rajiiv on 8 November, 2009 - 2:40 am
valve specifications are as below at normal flow
1. inlet pressure - 700psig
fluid - boiler feed water
differential pressure - 625psig
flow rate - 221 LB /HR
specific Gr- 0.94
viscosity - 0.3
pipe size - 1" S/160
please kindly tell me which valve to be selected if u can, sir. please show me what are the steps.
Advertisement
