from the Forum department...
Problem with Beckhoff BC9000 + KL6021
Local and wide area networking in factory automation. topic
Posted by mr24 on 10 November, 2009 - 4:12 am
Hello
I am beginner and I have a job with controller BC9000 of Beckhoff. I must read data on rs-485. I use module KL6021. I load example program from help of beckhoff, but I change my parameters. But it,s not working. I throw DOUBT on module KL6021. Its 3 leads glisten always. It is normal?
I add to program KL6configuration and my code is show down. State Busy of KL6configuration and ModbusRtuMaster_KL6x5B is already busy. Why?
PROGRAM pr
VAR
flag: BOOL := TRUE;
Conf: KL6configuration;
MBdataMy: UINT;
tempData: INT;
MBdata: ARRAY[0..99] OF WORD; (* The size of this array can be adapted to the modbus slaves register area *)
MBd: WORD;
ModbusAddress: ARRAY[1..23] OF BYTE := 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23; (* for 23 slaves *)
MB: ModbusRtuMaster_KL6x5B;
timeoutvalue: TIME := T#300ms;
busy: BOOL;
state: INT;
tick: DWORD; (* statistical data *)
lasttick: DWORD; (* statistical data *)
ModbusCycle: TIME;
Unit: BYTE;
temp: UINT;
tempo: BYTE;
doneKL: BOOL;
errorKL: BOOL;
busyKL: BOOL;
donewrite: BOOL;
busywrite: BOOL;
END_VAR
VAR CONSTANT
Mode : MBserialLineMode_t := MBSERIALLINEMODE_KL6_5B_STANDARD;
END_VAR
and the code:
MB.ReadRegs(Execute:= FALSE);
IF flag THEN
Conf(
Execute:= TRUE,
Mode := SERIALLINEMODE_KL6_5B_STANDARD,
Baudrate := 9600,
NoDatabits := 8,
Parity := PARITY_NONE,
Stopbits := 1,
Handshake := RS485_HALFDUPLEX,
ContinousMode := TRUE,
pComIn := ADR( pr.MB.InData),
pComOut := ADR(pr.MB.OutData ),
SizeComIn :=SIZEOF(pr.MB.InData),
Done => doneKL,
Busy => busyKL,
Error => errorKL);
MB.ReadRegs(
UnitID:= ModbusAddress[23], (* station address *) (*UnitID:= ModbusAddress[Unit], *)
Quantity:= 1, (* WORDs *)
MBAddr:= 2306, (*Adres na registara, koito 6te se 4ete ot slave-a*)
cbLength:=2 , (* 1 words (cbLength>=Quantity*2)*)
pMemoryAddr:= ADR(MBd),
Execute:= TRUE,
Timeout:= timeoutvalue,
Busy => busy );
flag := FALSE;
END_IF
IF NOT busy THEN
state := 0;
flag := TRUE;
END_IF
Globul variables is:
VAR_GLOBAL
Term_2_KL6021_S_State AT %IB0: USINT;
Term_2_KL6021_S_Data_In_0 AT %IB1: USINT;
Term_2_KL6021_S_Data_In_1 AT %IB2: USINT;
Term_2_KL6021_S_Data_In_2 AT %IB3: USINT;
Term_2_KL6021_S_Data_In_3 AT %IB4: USINT;
Term_2_KL6021_S_Data_In_4 AT %IB5: USINT;
Term_2_KL6021_S_Ctrl AT %QB0: USINT;
Term_2_KL6021_S_Data_Out_0 AT %QB1: USINT;
Term_2_KL6021_S_Data_Out_1 AT %QB2: USINT;
Term_2_KL6021_S_Data_Out_2 AT %QB3: USINT;
Term_2_KL6021_S_Data_Out_3 AT %QB4: USINT;
Term_2_KL6021_S_Data_Out_4 AT %QB5: USINT;
END_VAR
And variable configuration is
pr.MB.InData AT %IB1 : ModbusKL6inData5B;
pr.MB.OutData AT %QB1 : ModbusKL6outData5B;
END_VAR
Posted by Simon Hedges on 11 November, 2009 - 4:54 am
You could try posting this question on the TwinCAT Developers forum on LinkedIn http://www.linkedin.com/groups?gid=1860933
Posted by mr24 on 12 November, 2009 - 3:01 pm
Thank you for the link
Posted by War on 9 December, 2009 - 6:27 am
Have you set the KL6021 card up in KS2000. By default the KL6021 card is in 3 byte alternate mode with 9600 baud rate. You need to change this to 5 byte mode with standard (Uncheck the alternate mode check box). Then I see you are using modbus, but you have created 2 sets of link variables. You only need the variable in the variable configuration. So delete your global variable items. Once you have those done then your busy light should only come on when the Function block is busy. Hope that helps.
"An ounce of prevention is worth a pound of purge."
Advertise here
Advertisement
our advertisers
